Page 1 of 2 12 LastLast
Results 1 to 12 of 18
    Newcomer Array
    Jul 2005
    99 Civic Hatch
    StrutBrace Understeer?? (Civic)
    I've heard from someone I know that if you put a rear strut brace in an ek civic hatch. It causes it to understeer.
    Basically i got front and rear braces waiting for me, i'll just get the front one if the rear would cause bad understeer.
    Could you guys confirm if thats true or not?
    Cheers guys
    front will cause more understeer....rear will tie in with the rear rgidity more
    I had a carbing front one ( large and thick) and it increased frontal response , BUT every corner went wider and wider :S
    May 2005
    California, USA
    del sol
    I ran a rear bar on my sol for well, a day, and found it made it very difficult to keep traction in the rear. I also ran at the track(autox) several times experimenting with and without it, and consistently ran 1.5 seconds faster WITHOUT the bar
    Sep 2004
    101 MotorCafe Performance/Tuning
    01POV
    So you're recommending not to use a rear struct bar on track????
    |=TeamPOV=|=JDMYard=|=EK Squad=|=101 MotorCafe Performance Tuning=|
    EK Koni Yellows + King Spring Combo for Sale
    May 2005
    California, USA
    del sol
    Quote Originally Posted by barefootbonzai
    all I'm saying is that in my car, with how I had my suspension set up, etc, the rear strut bar was making me go slower and lose traction in the rear at a much earlier point. I don't know anyone else that's done a direct comparison, so that's what I did, and those were the results I got.
    (waiting for someone to come in and say that I'm wrong)
    I would spend the money on a rear sway bar WAY before spending any money on a strut bar as well
    Sep 2004
    01POV
    good good, i'll give my setup a go with and without a rear struct and see how it goes. Sould be arriving sometime dis week, can't wait
    i found with rear only = car is a bit skittish around corners
    with both front and rear = noticeable improvement over stock
    get both
  8. #8
    ROKAGESAMA Array
    Sep 2003
    Sydney
    2009 Lexus ISF
    both will stiffen up your chassis front and back
    front will improve stiffness in the front which will cause understeer
    rear will imporve stiffness in the rear which will case oversteer
    so having both will even out the car back to stock..
    but u will have a much stiffer car than stock..
    Team Bacchus Racing Lexus ISF
    Bacchus Energy drink
    Drive your Energy
  9. #9
    May 2005
    California, USA
    del sol
    Quote Originally Posted by dcdc
    get both
    I suppose I should have added that in my above mentioned test, I did have a front bar
  10. #10
    Needs more time... Array
    Aug 2003
    Sydney
    Blog Entries
    12
    Hows about the fact that the effect of a rear strut brace depends on the car. That is, whether it is a hatch, sedan or coupe......nobody has mentioned that ?
    Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
  11. #11
    May 2005
    California, USA
    del sol
    Quote Originally Posted by wynode
    well, that's part of why I specified my car and suggested people try it for themselves
  12. #12
    I needed the strut braces just to minimise twist on the track.....i reckon without them, my chassis is gone already. LOL
