Results 1 to 7 of 7
    Question re: A Pillar Rattle [Euro]
    I know this issue has been raised a few times. However, my question is whether anyone has had their winscreen clips changed/repaired to rectify this problem. If so, what was done by the dealer? Were new clips installed or adhesives used?
    I had a really bad rattle from new when temp dropped below say 10C (ie. in the mornings). Drove me bloody nuts! It was actually more like a crackling sound. However, based on advise on this forum, I got rid of the noise by pressing hard on the plastic strip where the windscreen meets the A pillar. The rattle is now gone except for really big bumps. However, the weather is also much warmer now. So I'm not sure if it'll come back. I'm thinking of getting the dealer to do something about it at the next service. However, I'm not sure if I should demand that the clips be changed irrespective of proving the rattle in a test drive.
    Anyone had their's rectified by the dealer?
    Jan 2004
    Melbourne
    ED Civic & 380GT
    Just press the windscreen cowl in a few times - in my case it was a permanent fix.
    Yeah, it seem to work for me too. So you reckon I should not get the clips changed or resetted?
    Jan 2004
    Melbourne
    ED Civic & 380GT
    Quote Originally Posted by FWCL
    Not unless it is happening. The less your car is pulled apart by some apprentice mechanic the better. It is like fixing rattles - dealers pull apart the doors and dash, etc, and sometimes create new rattles that are worse than the ones you wanted to fix!
    Agreed.
    I would not let the dealer rectumfy it.
    You may extirpate the rattle in question but pulling apart the interior will undoubtably result in other niggling rattles down the tracks.
    Aug 2006
    Veering right
    Euro Sport
    Rattles in front window
    I'm getting this annoying rattle in the drivers window too...
    Sorry to be such a newbie, but what do you mean by the windscreen cowl?
    Thanks
    Quote Originally Posted by yfin
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Quote Originally Posted by cgspot
    Thanks
    The huge black piece of plastic located between the windscreen and the bonnet. Where the wipers come out.
    Stocky CL9 - 1:17.2
