Page 1 of 2 12 LastLast
Results 1 to 12 of 21
    315whp NA H22 *ahem* H27
    Taken from honda-tech.com
    Link
    H27 H22 92mm bore/100mm stroke 315WHP/236WTQ dynojet---267WHP/201WTQ Mustang Dyno « » 2:33 PM 9/19/2005 Reply Edit
    H27 by Pocketrockets Racing
    Please keep in mind this is an engine designed for European autocross, it is not a drag racing engine.
    I have no problems making a purely drag race engine that can do +25 more WHP than this engine....I am well aware of the K and F20c series and all that Jazz. We are working on them too.
    In fact I can make a 2599cc engine with a box in box Wiseco piston with a quite short(relatively speaking) 95.6mm stroke for high RPM all out effort.!!!
    This is a Mustang Eddy current dyno, which is known industry wide to read 15% below the dynojet.
    It is well known that a standard H22a 190-200 crank HP h22a will make ~160-163 whp on a dynojet ...and 141-144 whp on a mustang dyno.
    This engine only has 12.8 : 1 static compression as this designed to run on and limited to 100 octane fuel.
    It also only has 272 degree @ 0.050" lift Crane roller cams, opting for this setup to have a broad midrange torque curve.
    We have achieved 267.6 WHP and 200.7 WTQ on the Mustang dyno, Independently done and verified at KVR performance, thanks Edwin and crew!
    This translates to ~ 315 WHP and 236 WTQ on a dynojet.
    and translates to 361-372 HP / 269-277 ft'lbs at the Crankshaft.
    Torque peak is at 5750 rpm and max HP is at 8000-8250 rpm.
    Tuning is done here, inhouse.
    Our goal was to have 90% of maximum torque, available from 5000-8000 rpm, which we have achieved. I am content with the results.
    some Specs of the engine:
    92 mm bore x 100 mm stroke
    Block uses Custom Darton ductile iron sleeves done by ERL Performance and further modified by us, for this unique application. Thanks to Jeff and Sean and Crew@ ERL
    12.8:1 static compression
    Importpowerhouse/RMF Custom 4 into 1 header with 2 1/4" collector
    TWM 52mm modified Independent Throttle bodies with full enclosed custom PRR airbox, IAC, CAI, K&N air filter, TWM FPR.
    525cc @ 43.5 psi Delphi injectors running at 52 psi fuel pressure
    External Peterson fluid systems oil pump, wet sump, run from in behind the OEM Honda crank Damper, inline oil filter.
    Crane/Ferrea 272 degree @ 0.050" lift roller camshafts
    Crower adjustable cam gears
    Crower 100mm custom billet crankshaft ....Thanks Brian and crew @ Crower's.
    Crower Endurance pro-billet steel rods
    Rod/Stroke ratio is 1.58 : 1
    Wiseco custom 92mm pistons and rings, lateral gas porting...Thanks Brian and crew@ WIseco.
    Ferrea roller rocker arms, valves, springs and titanium retainers
    Custom P13 cylinder head with all Porting/headwork done here inhouse
    Full 3 inch Thermal Research and Development stainless exhaust system with muffler, rear exit.
    Denso IK24 spark plugs with magnecor wires
    AEM Engine management System using OEM distributor
    Aluminum flywheel.
    Dyno run : 3rd gear pull...standard h box gearing....Sunoco 110 octane fuel.... Intake Air temperature were 118F-125F..........idles happily at 1200 rpm.....coolant temps never rose more than 10F during full 3rd gear pulls.
    BTW....even with the full roller cams....the car got ~ 30mpg at 75-80 mph .....pulls 5th gear happily from 3000 rpm with less than 0.75 volt knock...LOL
    I think I better make a 12.5:1 vtec one of these for my street motor....yippee....lol
    I already passed emissions with a 2.2L 12.5:1 stge 4 Crower cams, so the bigger motor should be no big deal......lol
    mines still better...
    Quote Originally Posted by preludacris
    i'm sure it is...
    what's your setup?
    i love that intake manifold!!!
    Quote Originally Posted by bigteethygrin
    that's actually a cover (with intake pipe attached) for quad throttle bodies
    Green block gangster Array
    May 2004
    twin GX160's
    awsome,
    Apr 2004
    wagga wagga
    CD5 vti-s
    Holy shit! good work guys! Is that an engine damper i see on the front of the engine?
  8. #8
    Quote Originally Posted by h22a accord
    Looks like one. Anybody know for sure? If ur after one i've got the link somewhere, prelude parts can be hard to come around i dunno if thats true for h22 accords tho
  9. #9
    thats mental man..
  10. #10
    Apr 2005
    Brisbane
    95 Honda Accord H22A
    hahahahaha you can see his feet in the photo... nice socks haha
  11. #11
    I was equipped by Mugen Array
    Sep 2003
    Perth
    Lexus Soarer V8 GTLimited
    Holy Crap !
    white explorer socks ~ yo !
    Honda resource for enthusiasts with all the latest news from Honda, downloads, media, photo albums, technical information and lots more!
  12. #12
