Vision / Spoon Carbon fibre Mirrors install on a Integra
Motivation / Description
well i love Carbon fibre hehe and they look great very nice mirror, its wider than standard and has a stylish blue tinge to it. The vision ones are cheaper than the spoon official mirror but vision make for spoon so the quality is top notch
these mirrors are not for everyone i personally love the look, i did weigh them 400grams compared to 960 grams for the standard so not much all counts though.
when you install these you loose the motorised function of the standard mirrors and have to adjust with your hand. i dont see this as a big problem casue how often do you adjust your mirrors ?
Installation ( pics)
Installation is fair easy just need
- Phillips head Screwdriver
- 10mm spanner / socket
1. First off start by removing the Door trim you can sort of skip this part, would be a bit harder and more fiddly so i decided to take the trim off. There are 2 metal screws one in bottom of the door handle and ones behind the unlock door leaver, there is also a plastic lug i have circled them in red remove all these la
2. Once you have undone the screws pull from the bottom there are some clips holding it on, but just pull and it will umm come off hehe, onece off you will see the triangle cover behind the mirror this is also just held on with clips give it a tug and it will pop off...
3. Pull off the power mirror plug 2 clips either side hold it in place. Then undo all the three bolts with 10mm spanner
4. The mirror still wont come off yet, you need to push the two tabs on the power windows plug into be able to remove the mirror, just use something to push them in, then remove mirror and put nuts back on the end of the screws so you dont loose them.
5. you can now just place the Vision mirror back into the hole they fit perfectly, screw the nuts back on dont overtighten its only a 10mm nut.
put it all back together
repeat on the other side of the car
The hey presto you have finished
and i dont know why but i dont have a pic right now of the finished mirrors whops ill post tomoz
conclusion / Place of purchase
Well im very happy with theses mirrors after a bit of adjusting they suit the car very nicley and will go great with a C/F Bonnet ( coming soon).
The wide angle of the lens is good to can see alot more...
thanks Hondar for supplying them just hit him up in Jdm Concept forum in the traders section
if you have any questions let me know
Wynode edit: Added disclaimer
