Results 1 to 11 of 11
    Mar 2004
    Melbourne
    DC5S but not for long...
    How To know when clutch is dead
    Just wanting t know when u to know the clutch needs changing?
    right now, my car isnt smooth of downshifts no matter how i rev-match
    the car isnt really smooth on upshifts neither, jolts a little bit
    but when i do the famous clutch test... which involves putting handbrake all the way up, then revand hold to 2000 and releasing clutch to a little beyond friction point the revs do not slip
    does that mean my clutch isnt gone and its something else?
    Green block gangster Array
    May 2004
    twin GX160's
    could be a glazed flywheel and or pressure plate.
    Sep 2005
    Northern NSW
    Had a 1990 ED Civic
    Could be many things, Spigot bearing is catching/damaged, pressure plate has damaged fingers, clutch needs adjustment for full clutch engagement(change and bleed your clutch fluid)
    ECU-MAN's points are valid as well
    Mar 2004
    Melbourne
    goddamnit... : ( well if i'm going to fix the gearbox i might as well change the clutch. this conflcits directly with me getting cams...noooooooo
    Nov 2004
    Westmead,NSW
    my car vibrates alot when i'm rev matching...
    like a lot, what could this mean?
    Nov 2004
    NSW
    EG6ish
    te way i found out my clutch was gone was:
    as i drove up a hill, with constant acceleration, the car began to slow down, and rool backwards.... with constatnt revs :/
    Ctrl + W
    Needs more time... Array
    Aug 2003
    Sydney
    Blog Entries
    12
    Quote Originally Posted by iamhappy46
    Depending on the actual problem itself maybe a worn engine mount?
    Does it jerk when you back off the throttle in say 1st ?
    Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
  8. #8
    another little trick- put the car in 5th, try to start it, if the car starts ure clutch is fried
    do the same up the hill if it slips its gone.
  9. #9
    Jul 2005
    Western Sydney
    94 EG, 11 Maloo
    Quote Originally Posted by runwaycrackwhore
    u mean with the clutch out yes?
    Power Of Dreams...
    VTECN
  10. #10
    yeah mate, so all its testing is if the clutch has bite or not
  11. #11
    Jul 2005
    Western Sydney
    94 EG, 11 Maloo
    kool ill try that
    Power Of Dreams...
    VTECN
