Results 1 to 4 of 4
    Aug 2003
    Stolen DC2R
    I replaced an exhaust gasket today (piping connected to the muffler)
    When i removed the old gasket, i found two gaskets, but i only replaced them both for one
    Also i didnt have any exhaust gasket sealent, so i didn't use anything at all
    My questions are:
    -Do i need to use two gaskets or is one ok??
    -Is it ok if i continue driving without any sealent on the gasket??
    All help will be appreciated
    Steve
    Needs more time... Array
    Aug 2003
    Blog Entries
    12
    I'm not an exhaust expert, but given that it is after the cat, as long as there is no exhaust leak from that area you should be OK.
    Aug 2003
    Stolen DC2R
    it leaks a tiny bit where i changed the gasket (rear muffler, after cat)
    it that ok?
    Aug 2003
    Blog Entries
    12
    If you don't mind putting up with the noise
    Might as well patch it up.
