Page 1 of 2 12 LastLast
Results 1 to 12 of 21
    Apr 2005
    US - Harrisburg, PA
    Acura TSX (Honda Euro-R)
    JDM Taillight Install w/ Tutorial
    Ok I installed the JDM Taillights with the amber blinkers today. It was pretty easy took me just over an hour to install them.
    The bumper is held on with 3 screws. 2 in the wheel well and one on the bottome of the bumper connecting it to the back of the wheel well. Last there are two clips in the middle between the exhaust tips.
    First screw that need to be removed at top of rear wheel well. One on each side of car.
    Second screw that need to be reomved from the lower part of the wheel well. One on each side of car.
    Third screw that needs to be removed on lower part of bumper about two inches in from edge of wheel well.
    You need to pop of this screw to access the 10mm bolt that is behind it. One on each side.
    Then remove this bolt. One on each side
    Then remove the two clips on the under side between the exhaust tips. There are two of them.
    For those of you that have removed the front bumper the rear bumper snaps off the same way once you have all the screws, bolts, and clips off.
    This is what you start with after the bumper is removed.
    Once the bumper is off start on one side and remove the 3 8mm bolts holding the taillight on from the inside of the car and then disconnect the cables.
    Then remove the two 10mm bolts shown here first. Then pull the taillight out and remove the screw that hold the plate to the light.
    After this remove the bulbs from the original light and insert into the jdm light. Then reverse the process to install the new taillight.
    Before: with factory tails
    After with JDM Tails: You cant really tell that they are different at all when they are off.
    Close-Up of JDM Tail: not lit up
    Close-Up of JDM Tail: blinker on
    Well I hope this is helpful to anyone that attempts to do this.
    Jan 2004
    Melbourne
    ED Civic & 380GT
    Not sure anyone in Australia will find this relevant as we have those indicators - but the write up is great for rear bumper removal
    Apr 2005
    US - Harrisburg, PA
    Quote Originally Posted by yfin
    really yours blink amber.
    Feb 2005
    Syd
    EM1
    Quote Originally Posted by cccoltsicehockey
    yup
    what colour is the USDM blinker?
    Apr 2005
    US - Harrisburg, PA
    Quote Originally Posted by Fr3aKi3
    yup
    our blinker is red.
    May 2005
    Melbourne
    2JZ w/2 snails
    yeh whats up with that? why do US cars indicate and brake light BOTH are red? its pretty dangerious, how can you tell if someone is indiciting, or braking?
    its not that hard to make brake red, and indicate yellow...
    Sep 2005
    Sutherland Shire
    Graphite Euro
    Our ADR's (Australian Design Rules) require indicators to be amber in colour when lit.
    Great work on the pictures for bumper removal
  8. #8
    Sep 2005
    Gold Coast
    JazzVibeS/Prado
    I had to look about 3 times to see the diff between the lights.
    Nice rear bumper removal guide though.
  9. #9
    Jan 2004
    Melbourne
    ED Civic & 380GT
    You really have gone all out on this JDM Euro conversion.
    If you had the TSX in right hand drive we could do a swap - I'll take the TSX and you can have my Euro. The money you have spent on modding can be used on shipping costs!
  10. #10
    Array
    Dec 2004
    Sydney
    Disco Potato
    it wont be a full JDM will it?
    i read somewhere u cant change the TSX dash to the euro/euro R dash even if u do switch it from left to RHD
    Fast and furious? I drive slow and luxurious...
  11. #11
    Apr 2005
    US - Harrisburg, PA
    Quote Originally Posted by stephen8512
    please let me know where you found this as the frame of the car is exactly the same other than the firewall and location of gas cap
  12. #12
    Nov 2004
    Brisbane
    CU2,3MPS,VESPA
    you're not really gonna change the dash are you?
    would be cheaper to move to japan.
