well on friday night in christchurch N.Z. Kelford did a couple of test runs in there civic. the first a mid 13 was just to make sure the car would stop etc.. the 2nd run the car made a 10.88 @ 125.9mph with a tune from an older motor (that blew up before racing) it ran a 1.57 60ft without there wheelie bars fitted. Kevin hopes to see the car make 330whp with its current motor and hopes to run low 10's if not go faster during this season.. The car is running a custom crank, rods, pistons, by all accounts its 2.3litre, 15.25mm lift cams, custom head work, roller rockers etc etc.. it runs a custom 4spd gbox using an H22 housing, ITB's, Hytech side exit header, race gas, 750kg with driver..
Congrates to the 1st 10sec FWD N/A in new zealand..
I dare say Online wont be far off running a 10 aswell, and i can say the same for myself, I've decided to no-longer try to run a 10.8 with a factory bottom end and have a few parts in transit to see the power go upwards..
The season and next should see the all motor class get better and better.
gary
