Hi guys
i have just performed an oil change a month ago, and i just checked my oil levels, and its almost empty!!!
so i checked underneath the bottom and the oil sump plug is leaking oil, and ive never changed the sump plug before....;
so i decided to tighten it a bit more, but as you tighten it to a specific point, and you rotate the wrench 1 last time to ensure that it is tight, the sump plug slips and becomes loose again.....
Does this mean i need a new sump plug?? or a rethread???
i have heard, that you need to replace the washers on these sump plug recently, is that true?? or shall i change the whole sump plug and washers from honda??
