yes, but how are you going to do that with the gearbox input shaft inside the clutch, wich is attached to the flywheel which is attached to the engine????
by brute force by the sound of it? are you planning on reusing the clutch?
i hope the gearbox/engine is supported from underneath or above via a engine crane !
IF you somehow manage to get that block and GB out ( somehow i think it will take some time for you) they do weight quite alot and will crush limbs and fingers...BE CAREFUL
