Results 1 to 11 of 11
    hey ppl,
    Just want to know what the differences are in the D series engines from the EG civics (i think) and the 2nd gen CRX?
    Thanks, Phill
    Needs more time... Array
    Aug 2003
    Sydney
    Blog Entries
    12
    The D series engine in the original CRX is the D16A8 similar to the EG Civic Si. Main difference is the ECU that the Si has (which gives it a bit more power).
    Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
    the reason why i ask is, cause i bought an engine gearbox from a civic Si so i could use the gearbox in my car, and the gearbox from the civic is hydrolic and mine is mechnical. Did these engines come with hyro gearboxes?
    there is a bar code on the gearbox which read :S20- 1019696
    thanks
    '99 DC2R/'88 CRX Array
    Sep 2003
    DC2R/CRX
    ECU is the only difference really - they are all ZCs with D series coding
    I thought they were both 130bhp.
    All D series gearboxes mount to the D series engines from what the yanks I know are saying.
    '99 DC2R, '90 BMW E30 318is, '88 CRX
    Aug 2003
    Sydney
    Blog Entries
    12
    Spoon, you are talking about the clutch being hydraulic. Please tell us exactly what car you have so we can help you out.
    ive got a 1990 CRX si
    Newcomer Array
    Sep 2003
    Edinburgh, UK
    88-91 CRX's and CIVIC's have cable clutch
    92-95 CRX's and CIVIC's have hydro clutch
    HTH
    John
  8. #8
    thanks for the help guys.
    One more question though, am i able to use the engine from the civic si into my 1990 CRX si??
    Cheers
  9. #9
    Sep 2003
    DC2R/CRX
    D series engines mate to D series gearboxes - but if you use the engine you may find you need to change the ECU.
  10. #10
    yeh i got the ecu for it, would i need to change the wiring loom as well??
  11. #11
    Sep 2003
    DC2R/CRX
    Quote Originally Posted by spoon
    They may have changed it between generations - I'd sugget getting a wiring schematic for eack and checking off each connection to the ECU -> ancillery/engine. If its the same, the plugs may have changed - in which case, get an auto-electrician to splice in the correct plugs rather than swap the whole loom.
    Can anyone help out with the wiring schematics for each?
