Results 1 to 8 of 8
    Unhappy $2300 f%#k up on tyres
    I just bought 2 sets of tyres for my SIR CRX 90
    Bridgestone potenza 540S 205/60r15 $1300 these are the ****
    AZENIS 205/60/r15 $1000
    For my track car I have a set of 15inch 7/1/2 three piece wantabees rims and my f#ck&n car is to low and the rear scrubs
    because of the profile. My everyday wheels are 17inch by 7/1/5 and they don’t scrub tyres are 215/35/r17 Bridgestone potenza
    Does any one use this 60 profile on their ride ...........
    and what type of tyres do you use on the track
    Have a try with these two online calculators, compare your track wheels and street wheels, then play around with the profiles etc. Find out what will be good for you.
    - Tyre size calculator http://www.1010tires.com/TireSizeCalculator.asp
    - Offset calculator http://www.1010tires.com/WheelOffsetCalculator.asp
    Sep 2005
    Northern NSW
    Had a 1990 ED Civic
    Personally, I would have gone for 205/55. Did you order these tyres or the tyre shop recommended these sizes to you?? If they recommended them, take them back and tell them they farked up and you want the correct size rolling diameter tyre.
    What are the wheel offset on the 15's in comparison to the 17's... Hopefully, they are the same ?!?!
    Otherwise I forsee tyres going cheap in the trading post...
    N14 Pulsar - VQ35 swap, Kelford C spec cams, 12.7:1CR, 6 speed HLSD, BC coilovers & 350Z 12.6" F brakes
    Smashed VY SS Ute: Teins, AP Racing brakes, Billet wheels, lazy 481rwKw TT kit - PICS
    Oct 2003
    Melbourne
    '88 Civic GL
    yeah, 60 profile is too big for 15" wheels. On a ED/EF CRX/Civic I would stick to 50 profile.
    Check out my ED Civic progress here: http://edcivicracecar.blogspot.com.au/
    Ozhonda Trader Array
    Aug 2003
    Sydney.
    EGK24A
    205/50/15 Dunlop Do2g for my EG Civic.
    JDMyard Pty Ltd
    25 / 317-321 Woodpark Rd , Smithfield , NSW 2164. Contact : 02 97572364
    Email : yonas@jdmyard.com , Facebook : http://www.facebook.com/JDMYard
    www.JDMyard.com
    i have run 205/55/15 SO2s before and they helped me clear my driveway
    sidewall was relatively strong - but 60 profile would cause scrubbing issues no doubt...
    tyres sound exxy for such an odd profile.
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    I think it might be your offset of your 15" your 17" seem fine.
    You might just need to get another set of 15" rims with a different offset.
    195/50 to 195/55 is about 1.5cm higher. I would assume the other is 3cm for a 60 series. Since the cars are designed with 55 series in mind then i would say it is not a prob. Check the offset that might b your problem.
    Evo IX - THE FINAL EVOLUTION
  8. #8
    thanks for all the replys. I'm going to get my car lifted going to go coilover and camber kit
