my mate was beten by a s2k a while ago, it easily beat the r33 and he was fairly shocked and was driven by an older lady! the r33 was stock just with BOV added. Hes got a full exhaust and about 160 170kw at wheels so would prob be closer now.
judging by 0-100 times kicking around id imagine the S2k would win. Granted the S2k is a little sluggish off the line, it would nail the GST-T in 2nd gear.
lolz on tat.
i rekon s2000 will give a good run with R32,32 gtst. it wont be much difference.
but if both with similar modz, straight line s2000 wont have much chance..
honda is more built for corners
stock for stock s2k easily as ive seen it before,
s2k is lighter, no turbo lag, higher rev range and also rwd so no traction issues
moded gtst with exhaust cooler higher boost then skyline
A mate of mine had an R33 running about 11psi (from memory) with an aftermarket cooler and he ran a flat 14 sec pass (car was otherwise fairly standard). So the R33 is a pretty slow car standard, its the ones that have been heavily modified that you need to worry about.
