Results 1 to 12 of 15
    Aug 2003
    Canb-Melb-Syd
    Long history
    bad idle after cleaning IACV
    Hey i followed the guide about cleaning the IACV. Basically removed it from the manifold and sprayed a **** load of throttlebody cleaner into it and let it dry for a couple of hours.. ended up fairly clean..
    i run the car for a few mins and the problem now is that the idle drops really low and just picks up to not stall.. like down then up to not stall then down etc etc..
    just wondering if cleaning it affects the idle settings.. if so do i need to raise them.. the car is cold as well when this happens
    ideas
    i have a b16a1 in a ef8 crx
    Banned Array
    Jul 2005
    Melbourne, Aus
    Hmmm
    just how low is it idling? do you have a manual for your car? i have a copy of it... (actually i dont think it includes the SiR/b16a1... hmmmm)
    Sep 2005
    Northern NSW
    Had a 1990 ED Civic
    Did you reset the ECU??
    N14 Pulsar - VQ35 swap, Kelford C spec cams, 12.7:1CR, 6 speed HLSD, BC coilovers & 350Z 12.6" F brakes
    Smashed VY SS Ute: Teins, AP Racing brakes, Billet wheels, lazy 481rwKw TT kit - PICS
    Jan 2006
    Colorado, U.S.A.
    Takes the IACV and ECU time to relearn settings.
    Dec 2005
    CL9 Euro 6MT
    Try cleaning the throttle body
    Green block gangster Array
    twin GX160's
    also try cleaning the FITV
    Aug 2003
    Canb-Melb-Syd
    Long history
    thanks guys..
    i have already kinda cleaned the throttle body..
    so most likely i will need to reset the ecu.. do i do this but just removing the ground cable off the battery for a while?
    then what, just start it up and leave it to reconfigure itself? how long approx
    it should rev high until warm then rev at 800ish rpm.. if it is then too high or low how do i adjust the idle?
    also i have read that the FITV is the fast idle thermo valve.. where is this exactly and what is its purpose.
    cheers
    Aug 2003
    HPR Workshop
    Honda Camira
    similar thing happen to me.. my car wouldnt even hold idle, regardless of how much i adjusted idle i couldnt get the car to hold idle..
    4 hours later.. i reved the ****er......... revved it nice.. it then idled fine
    Club EM1 Represents - member 01 of 01
    Dec 2005
    CL9 Euro 6MT
    The FITV wouldn't lower the idle revs, rather it would increase it. My car was idling at 3000RPM then I screwed the white FITV knob thing back in and the idle dropped back to normal. But anyway, screw it in and see how you go.
    The FITV is under the Air Intake with three 12mm bolts under it. Its showen in blue in this pic: http://img380.imageshack.us/img380/3387/throt19ck.jpg
    When you cleaned in throttle body, did you also spray into the piping going through to the sides? Maybe the idle bypass pipe is clogged. This would explain the idle difficulties at low revs.
    Or maybe when you cleaned the TB, alot of gunk made its way into other areas of the throttle body causing excess buildup.
    I would give the TB another good clean.
    ps. When I cleaned the TB, FITV, and IACV, I didnt need to reset the ECU. It idled normally straight away.
    Aug 2003
    Canb-Melb-Syd
    Long history
    thanks for that eurodude,
    i cleaned the TB a few weeks back.. only the IACV i did yesterday
    i reset the ecu and see how i go
    Aug 2003
    Canb-Melb-Syd
    Long history
    reset the ecu and started her up.. seems to be all fine now..
    maybe touching the accelerator the first time affected the settings
    Oct 2004
    Blown NHBP CL9
    when you adjust the fitv do you mean the plastic body inside? for low idle should the plastic body be wound in or out
    V T E C h n i q u e
    Since 2001
    OG Member #3
