Results 1 to 5 of 5
    Banned Array
    Feb 2004
    Perth, WA
    Mud Crow
    3 D to B Series Swap questions.
    Can the starter motor from a D16y8 be used on a B-series?
    With the mounts. You keep the d16 frame mounts, its just the engine mounts that need to be replaced? So that would be rear, left, right, gearbox and AC mounts?
    I have a chipped P28 in my car atm, if i just get the chip remapped with the specific stock rom for the motor i choose, ill be right?
    Aug 2003
    Sydney, Australia
    '94 Civic VTi
    No
    Just use the ones off the b-series. i dont think all need to be changed though
    Yes
    All this information would have been cover on h-t, hybrid honda and the rest of the honda sites :P
    Aug 2005
    Sunshine Coast
    dc teggy
    it may be able to be done - but would be a lot easier to use the B series. save time and probably money in the long run. hope this helped
    48USE honda integra FOR SALE
    see link:
    http://www.ozhonda.com/forum/showthr...96#post1545396
    Banned Array
    Feb 2004
    Perth, WA
    Mud Crow
    SO if i get the B18C motor, i need all the b18c motor mounts and all the b18c chassis mounts. so the Dc2 chassis mounts fit EK fine then?
    Feb 2005
    Perth WA
    EG5.9, EF9, EL2
    u CAN use your D-series MOUNTS but you will need B-series BRACKETS.
    A "MOUNT" IS THE RUBBER PART.. A "BRACKET" IS THE METAL PART THAT CONECTS THE ENGINE TO THE MOUNT.
    to use your D-series say power steering pump or Air con compressor, u need the B-series BRACKETS.
