Page 1 of 2 12 LastLast
Results 1 to 12 of 17
    does anyone have this gear changing problem?
    im finding everytime i take my car into high revs in 2nd gear and change to third, whether it be a quick or slow shift. it will crunch before actually going in.. really dunno wtf is up with that??? someone help? it doesnt do it wen im driving normally.. its only wen 2nd gear is above 6000rpm
    Dec 2004
    Sydney
    '99 Integra Type R.
    Sounds like worn-out synchro's to me - But check your oil level first.
    "Manual transmissions in modern passenger cars use synchronizer rings to eliminate the need for double-clutching. A synchro's purpose is to allow the collar and the gear to make frictional contact before the dog teeth make contact. This lets the collar and the gear synchronize their speeds before the teeth need to engage. " Take from the HOWSTUFFWORKS.COM site
    I was trying to get some of their diagrams...other stuff about gearboxs.
    http://auto.howstuffworks.com/transmission6.htm
    Hope it helps.
    CYA.
    Feb 2006
    Canada
    Civic
    Its your syncro. Im sure that at lower speeds where the gear shafts are not spinning as fast you can get it in the gear fine. Crack that case open and change those bad boys out.
    kris
    yeah dude,
    sounds like your syncro's.
    it would prolly help if you did a search cause this topic has been discussed several times before
    it will deffinatly help you out
    Team West Yo!
    1:15:0 @ Wakefield park
    When was the last time you change your tranny oil?
    Feb 2006
    Canada
    Civic
    Quote Originally Posted by vtml
    Do you have a GM dealership hey its worth a shot to ask right. Pick up some GM syncromesh. It has brought trannies from the dead to work again.
    kris
    well ill try changing transmission oil.. if not ill hav to take it to my uncle (hes a mechanic)..
  8. #8
    Jan 2006
    Where you live
    Nonda Tiburon
    yea man jus change the transmission oil .. i should get around to doin that aswel cos mine is givn me the same wen i try to get into 2nd. have to like nurse it in.
    try redline products. they are good man ther was a thread on them in the integra section not long ago.. expensive but good stuff. especially if ur car is getting on in the km readings..
    good luck
    ..OzHonda Spam Crew..
    ..We Welcome You Abourd!..
    DC2R/DC5R Parts for SALE!
  9. #9
    i got the exact same problem in 2nd to 3rd crunches any revs above 3000
    brought new oil today but cant seem to find the filler bolt, and i know DIY search onli came to b16A vtec closest...
    i have a b18a1 anyone know where it is?
  10. #10
    Ozhonda Supporter Array
    Mar 2005
    Castle Hill, Sydney
    DCFOUR
    yea i have the same problem at 6000 from 1st to 2nd, im gonna change the trans. oil and see if that makes a difference, if not ill get the synchros checked
  11. #11
    May 2005
    Sydney
    Honda Beat
    my car did that so i changed the synchro and its better but still not gone...
    i changed to redline oil shock proof its called
    that also made it a little better
  12. #12
    Newcomer Array
    Sep 2005
    melbourne
    dc2R #399
    redline lightweight shock gear oil is DEFINATELY worth a try, put some in my box over the weekend and its SWEET. seriously, i cant believe the difference its made. try this stuff b4 you worry about sincro's ya may just find your problem solved???? you can get redline from BURSONS in melbourne or just look em up on the net. im givin it the BIG thumbs up
