Was bored on the weekend so decided do it and take some pics.
Aim: Upgrade the grounding cable going from the rocker cover to the chasis. Most effective only if your existing cable is in bad condition/damaged. Pretty much the same deal for most DOHC and DOHC VTEC models in the Integras and the civics. Not sure about the preludes.
Required: x1 10mm socket wrench, 6AWG shielded cable (left over from my sterior install), plug/clamp for wire ends (forget what you call them!
Steps:
1. Undo the existing cable using a 10mm socket. Originally looks like this:
2. Get your cable and sercurely fasten the clamps to the end of the cable. Give it a small yank to make sure its fit nice and tight. Once its done, new and old should look something like this:
3. Simply slide the ring onto the bolt and tighten up using the same 10mm socket. Once done, she should look like this:
I didn't have any black cable left so I used the red. But you can always spray it black for the 'sleeper' look!
