engine = ADM b16a4
wiring = ADM b16a4 EK4 harness
ecu = ADM B16a4 ECU
All from halfcut.
Symtoms as follows.....
Reset ECU
Car runs perfect except no VTEC. (No codes)
Jump Service connector
VTEC works but cuts in and out from 5800 to redline. (Now im throwing 20 and 23, knock and ELD)
Disconnect Service Connector
Still throwing codes 20,23. VTEC works great but after about 30mins of driving the car starts to randomly begin to misfire, bogging down, stuttering under WOT at low rpms. After more time has passed begins to stutter more but in all rpms. After even more time. Car is only barley drivable with stuttering, missfiring and bogging down if anymore than 10% throttle is given.
FROM MY CONCLUSIONS I HAVE FOUND...
- VTEC only works if the MIL is on(throwing a code)
- Once VTEC starts working over time performence starts to go.
- Misfiring, stuttering sounds like ignition but what would cause the igniton to fail over time? ie one minute the car is driving well enoguh to chop a B16a2 with I/H/E, then 20mins later cant use hardley any throttle or it will bog down(simular to if you have your ignition timing fully advanced)
-Almost feels like pre-igniton.
ANY IDEAS?
PS can anyone do custom chips in Perth? Need an Open Loop only chip with ELD and KNOCK Disabled.
