when tuning quads, you ideally want something that can doa hybrid map/tps map(basically using map sensor vacuum readings for low throttle/load, and tps throttle readings for higher throttle/load). With hondata, you can't do this(unless things have changed in the past few months that I'm not aware of)... as such, it's really not suitable for a quad throttle body set up.
