I need some help on Vtecs im not really sure wot kind i want and i dont really know where to find places that specialize in motors in melboure can some help me out .
The first generation b16a comes stock in the following models :
EF8 CRX SIR (JDM Only)
EF9 Civic SIR (JDM Only)
DA6 Xsi Integra (JDM Only)
This engine is the 160hp/118kw versoin of the b16a and has a cable transmision
The second generation b16a, oftern refered to as b16aII or b16a2 comes stock in the following models :
EG Civic SIR (JDM Only)*
EK Civic SIR (JDM Only)*
EK Civic VTi-R
EG2/Del Sol CRX
EM1 Civic Coupe VTi-R
DA6 Integra Xsi (JDM only)*
Those models marked with an * are the 170hp/125kw varients of the b16aII, while the others are 160hp/118kw. All second generation models use hydraulic transmition
Differences between generation 1 and generation 2 b16as include :
-Gen1 b16a uses OBD0 ECU
-Gen2 b16a uses OBD1 (from 92-95), OBD2a from (96-98) and OBD2b from (99-00)
-Gen1 b16a has 2 Oxygen Sensors (02 Sensors)
-Gen1 b16a compression ratio is 10.2, whilst the Gen2 is 10.4
-Gen1 b16a heads will have DOHC in larger font than VTEC, whilst Gen2 has DOHC written in smaller font than VTEC
Thanks "n" i looked at half cuts once and a a b16a with hydrolic clutch would be the gen 2? If someone claims to have a gen 2 without this would that be a hoax?
Yes and a very comprehensive summary of the information i require. Been wanting to find that stuff out for ages, thanks dude!!
