Hi all,
OK I'm beginning to settle on the following rims which have some other options that require one to have bigger offsets. On the 17"x8.0 s I'm looking at there are at least two models with offsets as high as +57 and +64. It lists the higher offset for a model called "Deep Rim" and I'm not sure how these look compared to the usual since I don't know Japanese and can't understand the brochure beyond the superficial stuff (and sometimes helpful English).
So is an offset of +57 or +64 too high for a Euro? This rim has two offsets for each rim and I'm assuming that because these are two piece rims that they are fully reversible giving two different offsets depending on which side you attach it. There is a +45 (48) model which seems as if you could mount it either way in case you got the lip scratched etc. I'm not sure which one to select but I like the way the model in the picture looks where the spokes go out to the edge of the rim.
Anyhow I did a photochop of the rims I like onto a picture of my car to show what they might look like provided I can choose the right ones from the table.
The PDF file can be downloaded from...
http://www.work-wheels.co.jp/wheels/index/xs2/xs2.pdf
Any help is appreciated.
