Disclaimer: The following is provided as a GUIDE ONLY, and neither myself nor Ozhonda take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk.
Aim:
Change the Lights-Colour of your Ek dash (make it look more unique)
Required:
- Philips Screw Driver
- 1 Wedge Based bulp (I picked Arctic Blue) which is white when its on
- 4 LEDs (White)
- Time
Steps:
Remove the two screws from the top of your dash and remove the black plastic covering by just sticking your hands just under it and pull it slowly ... will come off (if you have trouble like i did just move it around slightly and will come off)
After the plastice covering is all off, remove the 4 screws around the corner of your dash (gauge) and it will come off.
pull it out and look at the back of it and you will find...
1 Big black housing (thats the one with the wedge)
and you will see black and gray housings too
now the LEDs are all one size so you can fit it in both grey and the black ones (the black ones may look smaller but will fit straight in)
to take them out you need to twist it and it will come right off
now some of the black/grey housings are for the warning signs so you dont need to replace all of them.
then stick it like you took it out screw everything back together and your done.
I dont have pics at the moment but will come in soon i promise
now as for the aircondition buttons etc ... im still waiting to be night time so i can see where the bulps are and what they need to be replaced with...
hopefully i get the pictures again but this should give you a good idea of what to do (as there is no DIY on how to get it done step by step)
Hope this helps you guys
Any question please ask ahead ...
