whats the point of a breather on a catch can?
to stop the pressure build up in the head which stops oil coming out of your oil cap...
thank you thank you!
Breathers on catch cans are a defectable item. You can't vent any gases from the engine directly into the atmosphere without going through the cat.
-------------------------------------- Stocky CL9 - 1:17.2
Originally Posted by MR_PEA to stop the pressure build up in the head which stops oil coming out of your oil cap... not in a honda. the OEM positive crank case ventelation system takes care of that...
B20VTEC - since 2002
so any point of a breather? better to have or not to have?
better not to have one on a catch can... the catch can shoudl be plumbed back into the intake manifold as it is supposed to be part of an emissions system...
No point on a Honda.
Originally Posted by aaronng No point on a Honda. (unless you are circuit racing it)
Originally Posted by tinkerbell better not to have one on a catch can... the catch can shoudl be plumbed back into the intake manifold as it is supposed to be part of an emissions system... that's what i thought, and with the breather it wouldn't really be plumber back.. thanks for the insight. would there be much point if you see the occassional mountain pass?
