i guess it is common to get noises with the whiteline bar, prolly best off re torqing the bolts n nuts just in case
i get noises with my 18mm wen i go on driveways
BTW vteccoupe, how's the handling since you got it fitted?
handles much much beta than the stock 1...i highly recommend this..best for buck mod for handling..i used to go real slow thru roundabouts but now i dnt nid to engine brake or watever...just go thru it and the car body stays in check...u feel in control..and u can take corners at a much higher speed with confidence
What does the sound, sound like? Metal on metal? Creaking?
I would suggest tightening everything down and just make sure everything is tight. You would be suprised that by making sure everything is tight will fix your problem.
See a good post? Give it a PQ point.
Originally Posted by ludecrs
They have the depreciation re-sale value of a burnt out and multi-rolled Commodore.
duno hw to describe the sound..metal on metal sounds too harsh....e sound doesnt sound as bad as metal on metal..just noises when going over uneven grounds or driveways
on my ek1 i had noise problems.
creaking was because the d-bushes were on too tight.
knocking sound was from swaybar hitting lca.
all fixed now and quite as.
