Page 1 of 2 12 LastLast
Results 1 to 12 of 14
    May 2004
    Melbourne
    '07 CL9 lux
    whistling sound when cruising
    ive noticed when im accelerating to about 80km then cruising at 80km,
    i hear a whistling / winding sound from the engine or something
    is this normal for a jazz?
    note... that its not a turbo... hahhahah
    should i take it to the dealer????
    May 2005
    Sydney
    S2k
    yeh i get that too even when i accelerate to 20km/hr,
    its the air being sucked into the engine by the air filter.
    i've got a pod so its more noticeable.. but it should be fine.. no need to take it to the dealer. think of it as ur blow off valve.. lol
    cheers
    jez
    May 2004
    Melbourne
    '07 CL9 lux
    its annoying tho
    think of it as a turbo spooling up
    LOL
    Sep 2004
    ブリスバン
    GD3 Vti-S, S15 Spec R GT
    Quote Originally Posted by -[NoS]-
    Do you have a pod filter? If you do then most likely the extra whistling sound is due to that. IF you hear a ticking sound at speeds above 80, its probably due to the gearbox or something as I hear a clicking sound too, but goes away if I hold the gear knob into the gear.
    May 2004
    Melbourne
    '07 CL9 lux
    nah... the jazz is stock as... its more of an electronic winding sound... i dunno
    ahha
    guess ill live with it
    mayb mention it at the next service
    Team YCD President Array
    Dec 2003
    Earth
    Honbaru Yum Cha
    Could be wind noise... Happens to lots of cars
    146.8Kws @ Wheels Diesel CL9 Euro (SOLD), 2009 Honda VT Shadow, NC PRHT Mazda MX-5, Boxing SG Forester, Honda Civic Sport
    RenaultSport RS265 Trophy+
    Team Yum Cha Daily - The Dim Sum Revolution
    OzHonda's Public Relations Guru
  8. #8
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    I get a high pitched whistling sound on my Euro as well. I thought it was the radio but the sound is still there when everything is turned off. It's probably from the intake (I have the stock airbox)
    Stocky CL9 - 1:17.2
  9. #9
    May 2005
    www.whotels.com
    2007 Cannondale Rush 4
    about a year ago, for about a month, i "use" to get that whining sounds, it sounded like a police car but in the distance..........
  10. #10
    Sep 2004
    Melbourne
    Mini Cooper S Chilli R56
    i have this faint whistling sound when i'm on light throttle...... gotta be from the aftermarket airbox... its annoying as hell...... donno how to get rid of it though.... i tried to clean the filter, even the throttle body inlet..... but doesn't help....
  11. #11
    Apr 2006
    Melbourne
    NEED DC2
    if you say its more of an electric whistle, try turning off your stereo and see if it goes away (dont just turn it down because the whistle will still be there with power to the stereo), if the sound does go away then it means your stereo is not earthed/grounded properly and you need to find a stronger ground
    normally this sound follows the sound of your engine, the higher the revs the more high pitched the sound (sounds volume does not change)
    if it is the sound from your pod then this also is not the best......though it does sound crazy when vtec hits and you can hear the air being sucked from the pod, you should have your pod conceled in some kind of box so as the hot air circulating around the engine is not being sucked in through your intake, only cold air from somewhere outside is...hot air means less performance
  12. #12
    could be ur airfilter if u have an aftermaket one.
    but as for me i get it from 0km to x km... hahah turbo spolling
    I haven't driven a Honda in years. :/ Does my honda lawn mower and whipper snipper count?
