Can someone please advise steps required to replace the air con belt. To gauge correct tension, how much should the belt move and how is it measured eg. pushing in the middle of the belt? Is this tension the same for the other belts when I put everything back together? (I've searched and can only find info on timing belt change). I will be doing this replacement on a 92 EG Civic. Thanks guys.
