YOu can get rears for about $350US + post if you hunt round, and as for fronts.... ebay? I know there is an interior headlight shroud going for like $20US.
But again, better to frequent US forums and such. I think the cheapest I've seen is $600US + post.
Yup. My housemate rashed her Smart against a pillar. We tried to cut it but it didn't work. Then we realised that the coloured panels on a Smart were made of plastic! So we took 800 grit sandpaper to it, sanded it down till the scrape was gone. Of course there were heaps of sandpaper marks. We went down to a finer grade (1200 grit) and then autosol after that. We used A LOT OF ELBOW GREASE. It's not easy at all, eventhough I was using autosol. Even autosol itself was not strong enough to remove the sanding marks from the lower grit sandpaper. So we had to go back to fine grit. If you want it perfect, keep going to finer and finer grits. Finally use autosol to get the shine back. And plasticX if you feel you need it after autosol.
After you have your shiny headlights again, remember to wax it! Yes, wax.
Yes, you can. Dont forget to post up pics of ur work, should come out using the above directions. Try get a before and after shot, maybe someone can make up a DIY to help others in the future.
]BTW can i just slap on a AP2 front bar wif the AP1 headlights??
Originally Posted by toE
Yes you can.
Originally Posted by J-MuN
I concur.
yes i slightly agree, you need to do some slight mods to the metal behind the front bar as we found in that other thread. Honestly for all your s2k issues ur best to head towards www.s2ki.com those guys in the US have done everything possible to their cars!!!
2007 BMW M3 Jerez Black/Palladium Silver
2002 BMW M3 Ruby Black/Black - SOLD
1999 Honda S2000 NFR/Black - SOLD
I agree with Rolled. There is nothing worse than being told it's a straight swap only to find out you need an angle grinder or you'll ruin your $700 AP2 bar.
okai i have been sanding, polishing, waxing all F**KEN day.. >.<
the driverside is all good now except at an angle u can see the damage still but its way better then b4 fanx to everyone who has helped me repair the headlights i realli thank you for all the help and experience u have shared wif me... ^^*..
i used AUTOSOL, MEGUIRES PLASTIC POLISH, 1000 GRIT, 1200 GRIT, AND A RAG,....
man im never goin to stuff around wif headlights nemore lOl...
fanx alot fellers again^^*
regards james
(ill post some pics when it was damaged and after the repair)
