Aim:
To get your turbo "SHI~"!!!
Required:
1 BOV
1 repco $10 tools
1 pair gloves
1 correct size pipe (can be radiator hose or steel one)
3 clamps
firstly, locate your stock blow off
HAHA~Here it is! two way to install BOV, u can replace the stock one with some aftermarket bov or locate it on the intercooler pipe
u can install here if u wish to
here the stock BOV, remove it by 2 screws, pull it out
replace the stock one by use the adopter
it is the one
install all pipe and screw it on, remember the vac line must be good flow
then the project done
Other comments
it is so fun to "SHI!~~~" with ur BOV, but dun forget it is defectable in SA and check around before play with it!!!WOH~~~~SHI!~~~~
11psi is the default spring and should be used if you don't know what spring to get.
Measure Vacuum at idle (engine at operating temperature
Vacuum Reading between -22 in/hg and -23 in/hg use -12 psi spring
Vacuum Reading between -18 in/hg and -21 in/hg use -11 psi spring
Vacuum Reading between -14 in/hg and -17 in/hg use -9 psi spring
Vacuum Reading between -10 in/hg and -13 in/hg use -7 psi spring
