Page 23 of 23 FirstFirst ... 1320212223
Results 265 to 269 of 269
  1. #265
    Yeah, have to remove tray... no loss really.
    I managed to use the stock mounting bracket for mine though.
  2. #266
    Feb 2012
    Accord Euro CL9
    18.5kg, wow that's a heavy bugger. Most ECU will have a limit to the amount of amps the engine pulls anyways, so in theory, a 730CCA battery won't start the car any better than a 430CCA one. Have you found it to be any different?
  3. #267
    Not really.
    CCA isn't really necessary, but higher CCA usually shows a larger amount of Acid / Lead which in turn is not taxed as hard and could lead to a longer lasting battery.
    It is however very useful in listening to music when the car is turned off and you may see a lovely 4 gauge wire leading it's way to the back of the car.
    Hopefully in the next few months that will be replaced by a 2 gauge or 0 depending on just how much money I drop on amps/subs!
  4. #268
    Jan 2016
    Accord Euro CL9
    55d23L is too big.
    I'm using above sizing and I had to take out the under tray and buy new battery strap down
    Does this battery improve the starting performance for your car Fred?
  5. #269
    Oct 2010
    '03 Euro [CL9]
    Quote Originally Posted by Martin77 View Post
    Nope.
    After 3.5 years (exact) it died yesterday. So I'm back at using 420cca small battery
    2003 CL9 5AT *ECU REFLASHED*
