Hi
I'm guessing your not in Australia as that Immobiliser Control unit differs from our Megamos Control Unit. Your friends ECU would probably be the P2P type (two ECU connectors) that is different to this DIY.
I can supply a bypass module for the Immobiliser if needed however you will need to post a picture of the inside of the ECU.
