They can be made to handel very good pretty cheap. il post on monday about it whan i have time,
couple of things to answer
Some 'imported' civics im sure had an efi engine - otherwise with an efi system in place ZCs are fairly easy to swap - yes.
Torsion bars:
gen1 CRXs as well as Civics used quiet thin torsion bars... *cant remember but - 14mm*
Interga torsion bars are probably the cheapest available - and swap straight in.
Otherwise : www.redpepperracing.com does have some posts on their forums where you can buy thicker torsion bars - some even purely for racing purposes.
Originally Posted by kayot1k
just as u can make anything fast as long as you have money,
same rules apply. itll handle just as good as long as you have plenty money.
although brand/type of suspension you buy is important also.
which cars handle best in stock form is a different story.
I understand and respect this, I just think that honda makes good fun little cars that can be slightly improved in certain areas (as honda has done itself with each successive generation, although they have to take into account other factors- safety/economy/what the market wants) and I dont want to be spending mega dollars to make a fun handling car- otherwise I'd just buy the lotus exige in light blue and call it a day.
Also honda has done much of the work here already- buy making engines which are easily (almost) transplanted between models.
--> Does anyone know whether the d16a8 engine swaps in? i know the d18a1 does... from the 1st gen teg. But is has less hp, is older etc. fat 85 civic- isnt this what you did? (or u used the old teggy motor...)
Originally Posted by asnpsuazn
you will be looking at changing all suspension bushings if you want it to be a thorough job. the labour and parts of this will set you back a lot in addition to the setup itself. something to keep in mind.
Yeah. I'm looking for a manual for this model to learn more about their sussy (still confused) and would prolly buy one when/if I get the car this week. I'd figure sussy parts included new bushings- something to replace as it got older/used, just like all disposables- oil/filters etc.
Torsion bars:
hmm well i think im looking to start with somethin cheap to work up with... i've not seen many 3rd gens for sale...
Fat85Civic swapped a D16A3 (brown top ZC) into his civic... but not sure if his civic was already EFi or not.
How much do you want to spend on a car? maybe hold off a week or two and keep your eye out for a gen1 crx.. every couple of weeks one pops up around the place...
MINT example of what is available!!! 1986 built with a 1.6 already!
only $3800!!!
http://www.carsales.com.au/pls/carsa...9&model_id=344
stock t-bars are around 20-21mm and teg ones are actually softer than civic ones.
My civic wasnt EFI but its really not very hard to swap over, all oy uneed to do is mount the pump and use soem rubber hose to join it all up.
To make it handle good quite cheaply all you need to do it lower it a bit, not too much or youll have no sussy travel, this costs abotu $180 as all you need is new rear springs, or you can use cut integra ones for even cheaper.
Some new shocks as the old ones will be stuffed
Weld up the rear swaybar, how to do this can be found on redpepperracing.com
and replace all the bushes, i got mine from america for $110
This is all i have done to my car for my suspension and it hanldes very well.
Im hopeing to get a front strutbrace soon from america but it costs abit in shipping so ill have to save up.
Luke
sorry to hijack but what engine's swap straight into a 84' civic? does a d15b4?
thanks and again sorry for the highjack
Luke
let me know when you're planning on shipping stuff, i might be in the market too, making it cheaper for us!
the less the better (more accessible) but a few grand. but if i buy my unrego'd i've got something to work on now, get to rwc then rego. rego will be about 450 so if i but it for 450-500 thats less than a grand. add 300 on fixing up little bits and pieces, $xxx for a new windscreen.... and its still running. than de ricify the interior (knob/wheel/pedals) and it'll be sweet. just looking for a teg donor car- maybe a wreck from hondwreck. hmm
Luke
Luke... are you 'sure' the teg ones are softer than the civic ones? u might be thinking of the civic wagon perhaps which are said to be thicker...
the ones available on redpepper are 24, 27 and 29mm right? 29 being the race use ones.
