Hi Guys,
Im currently doing a conversion from a D16Z2 OBD0 EF9 Concerto to a B16A JDM OBD1 using a P30 ECU.
Currently in the Concerto:
4th Gen OBD0 - 89-91 EF9 Concerto D16Z2 - Cable clutch - ECU has 2 plugs only.
Converting to a:
4th Gen OBD0 - EF Crx SiR 88-91 B16A JDM VTEC Engine using a OBD1 P30 ECU - 3 Plugs.
Question 1.
I need some info and diagrams of the wiring looms e.g. from Engine Harness to ECU Plugs of what wire is what, ECU Pin out Diagram with the Labels e.g. A1,A2,B1,B2,C1,C2, etc for the concerto and the B16A P30 ECU.
Question 2.
After doing some research and getting advise from several Mech / Auto Elect Guru's, they advised to use a PR3/PW0 ECU as it will make the conversion easier but others recommend to use the P30 as getting hold of the PR3/PW0 will be a biatch azz of sourcing.
"What would be the best ECU to use for my Concerto to match the B16A engine?, do i need to change the Dizzy on the B16A OBD0 and source out a B16A OBD1 dizzy?
Question 3.
Does the P30 ECU has the necessary VTEC wires e.g. Solenoid, Knock sensor etc on these ECU?
Question 4.
Is there anything else i should be looking out for? besides the differences on the O2 Sensor.
Any help or directions is appreciated.
