came across this link.. i find it very useful thought i would share...
link:
http://en.wikipedia.org/wiki/Honda_B_engine#B16A1
B16A
Note: All JDM B16a engines are marked as 'B16a' (with no number to identify version).
[edit]
- VTEC
- Found in:
- 1989-1993 JDM Honda Integra RSi/XSi (DA6/DA8)
- 1989-1991 JDM Honda CRX SiR (EF8)
- 1989-1991 JDM Honda Civic SiR/SiRII (EF9)
- Displacement: 1595 cm3
- Compression: 10.2:1
- Rod/stroke ratio: 1.74
- Power: 158 hp @ 7600 rpm & 112 ft·lbf @ 7000 rpm
- Transmission: S1/J1/Y1/A1
- 1991-1995 JDM Honda Civic SiR/SiRII (EG6/EG9)
- Compression: 10.4:1
- Power: 168 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
- Transmission: S4C
- 1992-1995 EDM Honda Civic VTi
- Power: 158 hp @ 7800 rpm & 116 ft·lbf @ 7300 rpm
- 1992-1996 JDM Honda CR-X del Sol SiR
- Compression: 10.2:1 / 10.4:1
- Power: 158 hp - 170 hp & 111 ft·lbf - 116 ft·lbf
B16A1
[edit]
- VTEC
- Found in:
- 1989-1991 EDM Honda CRX 1.6i/VTi (EE8/ED)
- Power: 160 hp (117 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
B16A2
[edit]
- VTEC
- 1996-2000 Honda Civic VTiR (EK)
- Power: 168 hp @ 7800 rpm & 113 ft·lbf @ 7300 rpm
- 1999-2000 Honda Civic Si (EM1)
- Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
- Transmission: Y21 S4C
- 1996-1997 Honda Del Sol VTEC (EG)
- Power: 170 hp (125 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
- Transmission: Y21
B16A3
[edit]
- VTEC
- Found in:
- 1994-1995 Honda Del Sol VTEC (EG)
- Power: 160 hp (125 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm
- Transmission: Y21
B16B
[edit]
- VTEC
- Found in:
B17
[edit]
B17A1
[edit]
- VTEC
- Found in:
- 1992-1993 Integra GS-R (DB2)
- Displacement: 1678 cm3
- Compression: 10.0:1
- Power: 160 hp @ 7600 rpm & 117 ft·lb (159 N·m) @ 7000 rpm
- Transmission: Cable~ YS1
B18
[edit]
B18A
- Non-VTEC
- Found in:
- 1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
- 1986-1989 Accord EXL-S/EX-S (Japan)
- 1986-1989 Vigor MXL-S (Japan)
- Displacement: 1834 cm3
- Compression: 9.4:1
- Dual Keihin Carbs
- Power: 130 hp (97 kW) @ 6000 rpm & 120 ft·lbf (164 N·m) @ 4000 rpm
- Transmission: A2N5, E2N5
[edit]
- This engine is not 100% related to the other B series engines. It is a destroked Honda B20A engine.
B18A1
[edit]
- Non-VTEC
- Found in:
- 1990-1993 Integra RS/LS/GS (DA)
- Compression: 9.2:1
- Power:
- 1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
- 1992-1993: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
- Transmission: YS1
B18B1
[edit]
- Found in:
- 1994-2001 Acura Integra "RS/LS/GS" (DC4)
- Displacement: 1834 cc
- Power:
- 142 hp (104 kW) @ 6300 rpm & 128 ft·lbf @ 5200 rpm
- Transmission: S80
B18C
[edit]
- VTEC
- Found in:
- 1994 Honda Integra SiR-G
- 1995-1997 Honda Integra SiR
- Power: 180 hp (128 kW)
- 1997-2001 Honda Integra (Japan) Type R
- Power: 200 hp @ 8100 rpm
B18C1
[edit]
- VTEC
- Found in:
- 1994-2001 Integra GS-R (DC2)
- Displacement: 1797 cm3
- Power: 170 hp (127 kW) @ 7600 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
- Transmission: Y80
B18C3
Power: 195 hp
- VTEC
- Found in:
- 1995-1998 Acura Integra Type R
[edit]
B18C4
[edit]
- VTEC
- Found in:
- 1996-2000 UK Civic 1.8i VTi Acura Integra
- Power: 169 hp (124 kW) @ 8000 rpm & 129 ft·lbf (174 N·m) @ 7500 rpm
- Transmission: S9B
B18C5
[edit]
- VTEC
- Found in:
- Compression: 10.6:1
- Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (176 N·m) @ 7500 rpm
- Transmission: S80
B18C6
[edit]
- VTEC
- Found in:
- 1998-2001 Honda Integra Type Rx
- Power: 200 hp (141 kW), 136 ft·lbf
B18C7
[edit]
- VTEC
- Found in:
- 1996- Honda Integra Type R (Australia)
B20
The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
[edit]
B20B
[edit]
- Non-VTEC
- Found in: Honda CR-V, Honda Orthia
- Displacement: 1973
- Power: 126 bhp @ 5400 rpm
- Torque: 133 ft·lbf @ 4300 rpm
- Compression: 8.8:1
- Bore: 84 mm
- Stroke: 89 mm
B20Z
- Non-VTEC
- Power: 146 bhp @ 6400 rpm
- 89 mm
copy and paste out of the page....
