Earthing could be a problem here Danny, check that its a secure connection to the chassis.
Also, did you install it yourself?
Are the power connections correct?
If you did it yourself did you use a multi-meter to check the input etc..
The actual wire connections should be solared onto each other not with electrial tape!
