i got myn done last month mikey
not really wat as i desired as, wen i had no power windows??? i got my alarm installed and what the lazy kunts did was use the power window loom (plug and play) and use it as a central lock motor source.
so what happens now is, had to get it rewired (still connected to the central lock motor) evey time i go up or down , the central lock motors gets tripped to. (driver side only) eg. wen i put it back up, it locks, and down, unlocks)
ebay wud haf some power window motors available as i know myn are from there...
u wud also need power window door trims+ window switches...
and electrician shud be able to do necessary wiring
"since we're both asian.. I'll look after you and chuck in King Springs with the wheels and tyres for $1050"
done it in my current EG
what u need is
power window door trim..
swtiches
the power window arms
regulators
and wirings...
u can use your standard indicator lines
but u must squeeze in the whole window (door plug) which is located between the door and the chassis
best way to tackle it is to rip off the whole front wiring from the underdash fuse box off a power window EG
and cut and paste it
ie repluging the 3 clips which are light green/teal coloured
the 3 plugs will contain the power source for your windows...
another set of 3 wires will have to run across your firewall to connect up the driver side and the passenger side..
mate sure u put in the regualtor with out it the windows wont power up
i spent about 200-300 for the window conversion and took me about 2 hours mucking about on 1 side and 30mins after i was familiar with it
Team Bacchus Racing Lexus ISF
Bacchus Energy drink
Drive your Energy
