Hi All,
After fixing all the other problems i had, my car has decided it wants to hold its breathe and over heat....
Just normal driving, temp will raise just below the red. i turn the heater on to reduce the temp (which works).
What's weird is that it isn't consistant. Same driving, same trip, nothing, the next day, it'll heat up.
i've been checking the coolant, the bottle sometimes empties..then when i check again..it's absolutely full!
i've been checking my oil...and it's not as dark and sticky as oil should be. looks thinner and lighter.... i have a feeling that coolant may be getting into the oil somehow?
should i remove the spark plugs to see if there's coolant in the cylinders?
My fan works fine, operates when it should. Radiator seems fine.
HELP!!!!!!
