Results 1 to 5 of 5
    Feb 2006
    Sunshine Coast
    1990 ED3 HONDA CIVIC
    front and rear tie bars
    has anyone got a picture of a front and rear tie bar installed on their car having troubles understanding where they fit.
    thanks
    Noob crowd controller Array
    Sep 2004
    Civic
    The rear bar is installed using the same bolt holes as the rear lca's. It sits just below where a sway bar would normally be placed:
    The front sits in a similar sort of position:
    **Note they are not pics of my car .
    See a good post? Give it a PQ point.
    Quote Originally Posted by ludecrs View Post
    They have the depreciation re-sale value of a burnt out and multi-rolled Commodore.
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    measure the ends and you will see where it sits. It can only basically sit in one spot.
    The front is where the 2 main bolts that hold the front control arms in. The rear is the 2 main bolts that hold the rear control arms. Pretty simple.
    Evo IX - THE FINAL EVOLUTION
    Aug 2005
    EG5>GD3>CL9
    *OT* is there much point installing rear tie without upgrading sway bar.
    have heard many mix responses.
    Oct 2004
    Jazz EVO IX
    i put my tie bars on before i put my swaybar on and i noticed a difference. It made the car less jumpy when steering into corners at high speeds.
