Results 1 to 11 of 11
Thread: Accord splits
    Feb 2004
    '94 Accord
    Is there any chance of finding splits that will fit the stock location of the woofer AND tweeter?
    I've found some i am interested in, but they have a mounting deth of 61mm, is this too deep? and the tweeter is 1", would that fit?
    Aug 2003
    94 Accord Vti-S
    i dont think u can fit tweeters in the stock spot
    firstly, the shape is odd, so will look shit, and secondly its a bitch to get to.
    As far as staging and imaging is concerned, the tweeters are best located down in the kick panels on the Accords.
    Feb 2004
    '94 Accord
    Quote Originally Posted by Calvo
    thats what i was thinking...
    marty, PM
    Feb 2004
    '94 Accord
    Does anyone have some sort of tutorial for installing splits?
    Ive searched the net but couldnt find too much on a 5th gen.
    This would be VERY much appreciated if anyone could help out.
    thanks
    I've written an article on staging if you're interested. Or do you mean physically mounting them?
    The article is here if your interested:
    Okay, lets all think about staging for a second. You don’t go to a concert and sit with your back towards the band right? And admit it – we’d all like to be right in front and center of the band on stage true? And you’d also like to be at the right height to – like you were on the actual stage right in front of them listening. This is the imaginary image we try and capture inside cars today when we position tweeters in vehicles.
    And getting this is not just a simple matter of slapping them in just anywhere either.
    The problem with mounting tweeters up high (e.g. on the sail area on the door) is this:
    Think about the position of your ears in relation to the tweeters. One speaker is belting the high pitch tunes out about two feet from your right ear where as the left tweeter is triple that distance away. The stage has no choice but to be right out the right window. Sheer laws of physics govern this fact.
    Now if you place the tweeters down in the kick panels then the right speaker distance is about three feet and the left speaker is about three and a half. The problem is not eradicated but it becomes a lot less noticeable as the distance separation is reduced.
    Now obviously the tweeters cannot be placed anywhere where they fire straight into ones feet so you have to be very careful about their placement on both sides and the more often than not this results in them being mounted very high in the kick panel, quite often out of sight like mine are because they’re so far up under the dash.
    The next question people ask is this; isn’t the stage going to be low?
    The answer is nothing to do with the tweeter location but the power level they both receive. If you have sufficient power going to each tweeter from a high quality amplifier then your tweeters will not only fill out the stage ‘height’ but the entire front cabin of the car.
    And someone is bound to mention time alignment – they always do.
    The biggest problem with time alignment is this; the better you make your side sound (and you can get it absolutely perfect), the more your passenger suffers. Think about it – it time delays the right side speaker so both signal paths reach your ears at the same time. The problem is that the passenger has the reverse problem to you so as you side gets closer to being the same side to side, theirs get worse and worse.
    So how does one get the stage right in real world terms?
    At the end of the day you just have to play around a bit (and sometimes it can take up to four hours or so) to get the tweeter placement just right to achieve a nice stage ‘width’ , ‘height’ and ‘depth’.
    Get yourself a nice big blob of blue-tac. Stick the tweeter onto a panel somewhere and grab a song with powerful female vocals (a strong female voice is generally considered best for stage testing). Close your eyes and imagine you’re at the concert. Now listen to where she is coming from. Is she singing right in front of you? Is she off to the left a tad or right? Simple move the tweeter a few inches in a direction and have another listen. How is the image? Can you hear where all the band members are exactly? How is the depth? Does the drummer sound like he is behind the other musicians?
    Keep doing this until you get the image dead center or just off to the left a little bit but remember to take a rest every fifteen minutes to let your ears normalize. If you attempt staging for hours your ears tend to ‘hallucinate’ and give false readings.
    So there you go, I hope all that made sense.
    Feb 2004
    '94 Accord
    Thats an interesting read.
    So the placement of the midbass is much less important than the position of the tweeter.
    So in this pic here, where have you (or any other member) found is the best position?
    OR do you mean inside the car?
    something like this
    No, usually we place them further away, like near the firewall. I don't think that position in the 'Q-Pod' pictured above is a very good location.
    Feb 2004
    '94 Accord
    Quote Originally Posted by Fhrx
    Can you be a little more specific (me knowing very little about cars), i know what the firewall is, but where exactly are you meaning?
    Roughly inline with your toes when you're seated. Further towards the front of the car.
    I can take a photo of my car and show you where he means if you want!
    Marty put mine in
