Results 1 to 7 of 7
    Nov 2005
    Bogan from Logan
    EG
    Request: Painting Calipers
    Looking for a nice howto to properly paint your brake calipers. Not a yum char job.
    Jun 2005
    Silverwater Correction Centre
    Camry
    I'm also looking to learn how to.
    Jun 2005
    syd
    560hp
    take em off.. clean throughly, cover upt he slide boots and the slides. pistons, and bleeding nipples.
    and start spraying a light coat.
    wait.
    the spray the next coat(s) until what your happy with.
    put em back on and then bleed the brakes.
    I just left mine on.
    Removed wheels, lightly sanded the calipers. Masked off the areas I didn't want painted, and then threw a towel to cover them a little more.
    Painted a light first coat, then kept coming back every 30 mins (not much drying time because I gave them each 5 minutes on the end of a heat gun (blow dryer for men, can get it for like $25-30) and ended up doing about four coats each. Didn't use a clear coat.
    Make sure that you use proper brake spray paint, can be had from autopro/supercheap etc. You need this special paint since your brakes can get up to 700Deg Celcius, and other paints will just melt off.
    Quote Originally Posted by mugeneration
    Well I always thought to PLEASURE your girl was anything sexual.
    To PLEASE your girl is anything that costs money.
    Moderator Array
    Jul 2006
    MELB.
    RiceTrolley.
    Quote Originally Posted by destrukshn View Post
    y bleed?
    凸-_-凸
    Jun 2005
    syd
    560hp
    Quote Originally Posted by m3ntAL_l2 View Post
    y bleed?
    depends if you wanna take off the whole caliper or not.
    Ozhonda Subscriber Array
    May 2004
    RX450h / RB3
    yeah if u want to do it properly better take off the whole caliper, but make sure u know how to bleed the brake after that, on mine i did about 5 coat
    heres mine:
