ahha na na, thats onli to show the pod, i put a box around it to keeep engine heat out. also removed the resonator out and fed a CAI pipe up the res hole to feed into the pod
I had a K&N Typhoon CAI setup in my prelude, the thing really gave a lot more power in the VTEC zone, (5300revs and up), but i thought car had lost a little bit of power in lower revs as the intake setup has longer piping, meaning longer time for the air to get to the intake manifold. The setup costs me about $380 and was worth every cent, especially on nice cool days, the power difference was huge throughout the whole rev range but in hot days low end power drops off a bit. This set up can be used as a short ram or cold air intake setup, but with the cold air intake setup i could not get defected as police could not work out whether the air filter was exposed or not. This mod also added a really nice roar to the car throughout the rev range particularly when VTEC was engaged. Hope this helps.
u went to all that effort and didnt want to spend 80 bucks on a mandrel bent pipe or one intake pipe off ebay???
companies like aem run R&D, uve just stuck a pod on the end of a pipe with R&D but only when used with the factory intake setup.
the set up from the guy who posted his pics is actually quite a good one.
i have had my set up simialr to his. the reason to why using the standard rubber piping is because of the excellent heat resistance to it.
the main idea was to reduce the obstruction of the BOX, resinator and increase the cold air induction.
and also if apexi makes one of the best intakes with best preformance etc.. then this set up mimicks it...
this is my set up, i use to only have a straight 3" pipe from existing OEM pipe to filter, but now i have enahnced the set up with a 3" 50 degree bend stainless steel pipe from the OEM pipe to the POD.
i have also produced a heat shield for heat protections... also my heat shield is protected internally with rubber. All this included a cool air ducting from the front bar as "luding"
ohh by the way, i do believe my improved in power.
Reason: added DYNO run.
