2006 VTi Civic - Speaker Covers
Hi all,
Just picked up a new Silver Auto VTI Civic on Saturday and already thinking of changes. I am looking to replace the OEM speakers with something better.
Can anyone tell me how the rear speaker covers come off, I have had a good look and the cover appears to clip off but i tried gently to pry it off but no luck. I dont want to break the clip so any suggestions would be appreciated.
Whilst on the subject, do the front speaker covers come off as well or does the whole door trim need to come off first?
the rear speaker basically u need to take off the whole parcel at the back,it's a bit hard to pry them off u need a bit of torque, there's a chance the clips will break.
for the front covers, the whole door trim need to come off, as the covers are parts of the door trim.
hope that helps
cheers thanks for that I will give it a try.
good luck
hope that helps
A bit of torque?
http://en.wikipedia.org/wiki/Torque
Have a look in the boot and see if there are any clips which you can squeeze and push/nudge out, do this first before you decide to just yank out the rear parcel shelf.
hope that helps
The rear speakers are accessible by removing each panel, its does not require you to remove the whole parcel shelf.
The speakers are clipped into the shelf on one side and theres a really long screw on the other.
If you look from the outside you should be able to see a small slit at each grill... a small flat head screw driver in that slot and alittle pressure will lift the panel out.
Finally got around to taking the back covers off, thanks wassup, they do come off very easily once you find the spot where they pop up.
Underneath I found some very crappy 6 inch speakers, just begging to be replaced
Now I just need to find some good replacement speakers. I thought about using some aftermarket amps but I dont want to have to run the power cabling through the car so I will just stick with the standard power from the head unit.
I've still got stocks in the rear.. planning to make the change whenever I get round to it. As I said somewhere else... I always thought front 2 speakers + sub would be enough, but then after trying out a sound system where both front/rear had been upgraded... wow.
my only concern is that using the standard power will not bring great results even after upgrading the speakers.
Perhaps someone could tell me otherwise?
Originally Posted by DamienS
my only concern is that using the standard power will now bring great results even after upgrading the speakers.
very true indeed... I think its a lot better if we install a 4 chnl amp to the new speakers... btw, any1 notice that the "tweeter box" is empty?
Hey guys, just got a pair of new rear speaker and tried to DIY them. Ive managed to get the covers off n all and gotten to the part where i just need to connect the wires to the speaker. I know this might sound like a stupid question but does anyone here know which wire is positive n which is negative? Theres a brown n white wire if that helps explain it a lil more. Ive searched through the forum n found some stuff on DIY installation of speakers but nothing thts really specific to the 06 civic. Right now my cars running on just the two front speaker cos i dnt wanna risk connecting the wires to my rear speakers the wrong way around.
I know its sorta a noob question but its my first car and first car DIY.
Any help would be greatly appreciated.
Cheers.
Asian models have tweeters.
