You can't pull down from gear to neutral without feeling resistance. And it is bad for your gearbox. So for the 99.99% of the time when you are driving on the street, you press the clutch in fully and then shift. For that 0.01% of the time when you are at the drag strip, you can find the actual clutch release point where you can pull it from a gear to neutral without much resistance. That will help you speed up your shift on the drag strip.
