Results 1 to 12 of 12
Thread: Hybrid B20B
    Feb 2004
    melbourne
    Is there a problem with using the B20B crank when doing the B16A head and B20B block combination, as i have just built one using Argo rods and Ross pistons And B20B crank
    Is this wrong ??????
    '99 DC2R/'88 CRX Array
    Sep 2003
    DC2R/CRX
    I think Chuck (ALLMTR) used the B20B crank in his 12 second CRVTEC 3rd gen Civic. Try PMing him
    '99 DC2R, '90 BMW E30 318is, '88 CRX
    If I was building with Argos and Ross, I would go B18c crank but that's just me
    the b18c is a smoother crank from what ive been told by my close mechanic, its able to rev out nicely, and better for NA from what he said.
    Since the b18c and the b20b share the same stroke length, its the better of the 2 to have.
    Quote Originally Posted by pornstar
    Pornstar they are not the same stroke B20B is 89mm stroke and B18C is 87mm stroke' so by using the B18C crank you change the rod ratio which allows you to use more RPM.The B18C Integra Type-R crank is an even better choice to use in this combo and if you need one PM Toda Australia as he does a very good deal on them.
    Regards Dyno Dave
    Buddyclub Australia
    Member of Master Of Vtec Group
    Feb 2004
    melbourne
    so what sort of RPM range does using the B20B crank limit you to before it becomes unreliable compare to the B18c crank?
    By shortening the rod doesent that mean you lower the gudgen pin in the piston which i was told is a problem ......not sure if this is correct?
    By using the B18C crank you are using 2mm LONGER conrods which gives you a better rod ratio ' you use the same pistons so the gudgen pin is not lowered.
    Regards Dyno Dave
    Buddyclub Australia
  8. #8
    The B18B LS engine shares the same stroke as the B20B.
    Regards Dyno Dave
    Buddyclub Australia
  9. #9
    oops, my bad! i stand corrected.
  10. #10
    If you have already built the motor it is a bit late to be asking for advice :?
    If you are running argo rods you should have no prob turning it to 9000 as I was going 8500 with stock (weak) B20 rods
  11. #11
    Quote Originally Posted by ALLMTR
    LOL!
    harmonics above 8500 will be an issue if high compression (>11.5:1) is being used.
    a block guard will help here...
    teh crank and rods are less of an issue compared to the weak tops of the sleeves...
    B20VTEC - since 2002
  12. #12
    Aug 2003
    Melbourne VIC
    baron
    I read sleeves were a real issue on the B20B, hence the reason a lot of the US guys getting resleeve before doing any major CR increases. Not that I really need to know :shock:
