Results 1 to 11 of 11
Thread: 100K service
    Feb 2006
    Sydney
    S2000
    100K service
    What does the 100,000 Km service entail?? Or what is recommended for the 100,000 Km service?
    Oct 2004
    Melbourne
    1998 EK civic
    read ur book champ
    Feb 2006
    Sydney
    S2000
    I don't own a S2K yet....just been looking around the market and noticed a few for sale with high Kms, so just want to know what else I need to budget for.
    Jun 2005
    sydney, Hurstville
    2000 323I, 2003 320ci
    100k isnt a major service
    the 80k is major. and the 40k is the 2nd biggest service
    Jun 2005
    sydney, Hurstville
    Inspect *
    * Fluid levels
    * Lights, horn, wiper washers and warning lights
    * Test drive (check all systems and controls)
    * Steering gearbox and tie rod end boots
    * Suspension components
    * Driveshaft boots
    * Air cleaner element
    * Front and rear brakes
    * Headlight alignment
    * Brake hoses and lines, including ABS
    * Cooling system radiator, hoses and connections
    * Air conditioning refrigerant level
    * Air conditioning condenser
    * Exhaust system
    * Fuel tank, lines and connectons
    * Tyre condition
    * Idle speed
    * Inspect, and if necessary adjust and clean. If replacement is required, additional costs may be incurred.
    Replace
    * Engine oil
    * Engine oil filter
    source: HondaOne.com.au
    Jun 2005
    sydney, Hurstville
    see? small. only things needed to be replaced is oil and filter. a very small service
    guessing it'll be around $300 or less from Hanny's performance in syd
    not even that, i believe its should be around $160 from a good independent. $300 from a stealership
  8. #8
    Aug 2005
    Sydney
    03 Indy Yellow S2000
    Quote Originally Posted by yellows2k View Post
    both of you are getting rorted
    $120 from Hannys and $290 from Honda - homebush .
  9. #9
    Jun 2005
    sydney, Hurstville
    im nowhere near my 100k servicce so im just guessing
  10. #10
    So can someone tell me what the 80K service do, b'cos my S2K is going to be 80K very soon.
  11. #11
    Jun 2005
    sydney, Hurstville
    80,000 km or 48 months (whichever occurs first)
    Inspect *
    * Fluid levels
    * Driveshaft boots
    * Parking brake
    * Exhaust system
    * Tyre condition
    * Valve clearance
    * Air conditioning clutch operation
    Replace
    * Engine oil
    * Engine oil filter
    * Fuel filter
    * Rear differential fluid
    * Transmission fluid
    * Engine coolant
    there
