Results 1 to 10 of 10
    Sep 2004
    Adelaide & Melbourne
    Removing hand brake cover on CRX...?
    Hey all,
    I have a bit of a weird question.
    I'm wondering how to remove the handbrake handle on a Gen II (Jap Spec) CRX. (The plastic bit your hand grabs covering the leaver not the metal brake lever itself)
    I want to put one of those after market silver handles on and I can't seem to be able to remove the old one.
    It seems pretty damn secure, does anyone know any tricks, does it screw off? or pull off? Or is it permanently stuck on there?
    I've seen one of those after market things on an Aus Spec CRX, surely there is no difference?
    Any help would be most appreciated!
    Cheers all!
    *Solved! Yes the handle just slides off (Both Jap and AUS spec) *tips: Wait for the car interior to get really really hot so the plastic expands :P or like CRXtasy said maybe use some lube :P Kinky!
    Feb 2004
    Adelaide
    Silver Coupe
    i know for a fact that on a pulsar they are part of the assembly(no idea about CRXs tho).
    and attempting to remove the plastic handle results in destroying the handbrake mechanism (had to go down to Upulit to get a new one)
    hopefully someone around here has fitted an after market one to a CRX before
    Sep 2004
    Yeh im begging to wonder....
    I've seen it on an AUS delivered, but this Jap spec one seems pretty bloody attached. lol
    Hopefully someone can help :/
    Feb 2004
    Adelaide
    Silver Coupe
    does the button screw out(make it like a drift handbrake?)
    Mar 2005
    EF8 CRX
    Yeh man it just pulls off, try and twist it side to side as you're pulling...it can be a bitch to get off.
    Sep 2004
    Quote Originally Posted by crxtasy View Post
    lol you 100% sure about that? On the Jap spec model? It feels like the bloody thing is glued/bolted on. I have tried twisting and it won't budge 1mm :/
    I'll give it another good shot tonight and see if I can get anywhere with it.
    Thanks!
    Mar 2005
    EF8 CRX
    Yeh it definitely pulls off, there's no difference between jap and aus spec, remember it has been on there for maybe 16 years, try squirting some lubricant down inside the middle of it.. that might help, and becareful not to launch it into your a/c control panel or stereo when it finally comes off.
    Sep 2004
    lol thanks for your help mate.
    I managed to get it off yesterday. lol. Interesting trick.. leave the car out in the sun! The car was so hot, im assuming the plastic expanded a little and it came straight off
    There was no way it would have come off that easily the other night, i was using full strength and it didnt budge. After the heat it pulled off easily
    Maybe a trick to remember in the future.
    Anyways, case closed. Thanks for the help!
    •CRX• represent Array
    Nov 2003
    CRX+CBR250RR
    next minute u try to pull up the handbrake and next minute Kink! :S
    SHIVERSS!!! :O go chase ur crx down teh street haha
