The clutches in the euro's seem to dry up which creates this noise.
This can be caused by the clutch overheating.
It's your spigget bearing that's running dry.
Once the clutch warms up and metal expands you rarly ever will hear the noise again if the bearing are just dry.
But if you have overheated the pressure plate you will get this noise when slipping the clutch even when it's warm.
It's hard to answer until the clutch is pulled down.
