Hey guys
Basically i have a greddy turbo kit on my D16y1 Eg Civic VTI. It is running a greddy piggy back ecu (looks to be wired into the map sensor) with a Td04 Turbo. now when comeing on full boost (7psi) the engine check light seems to come on, which (correct if wrong) seems to put the car into safe mode which seems to make the engine idol a little higher... It doesnt seem to be a very serious problem and all you have to do it turn off ignition and then restart and its gone!
Any cheap quick and easy way of getting around this? i have had a few suggestions such as a map sensor to read more boost? possibly 3bar? or check valves? or even a piggy back comp such as a vafc ?
I never even knew that civic map sensors could read boost? what do they read standard?
Anyway maybe shoot some ideas my and and start a discussion about it, any help is very much appreciate and i dont mind shooting over some post credit points...
Thanks in advance
Regards Lyle!
