Easy, if your using the oem map sensor, and your managment system isnt designed to fool the stock ecu reguarding the air pressure, than your gunna need to upgrade your map sensor to a 2bar/3bar sensor. Your ecu is currently going into safe mode as the map sensor isnt designed to work with positive pressures. Cant believe it hasnt been said sooner, and i dont even own a boosted car yet
If this is the case, which im putting all my money on, you will see the exact symptoms your describing.
