Results 1 to 10 of 10
    Newcomer Array
    May 2005
    melbourne
    94 crx
    turning key in ignition?
    i have a 94 crx.
    im having trouble turning th key once its in the ignition?
    sort of like when the steering wheel locks and u cant turn the key.
    but the only way i can get it to turn is by rolling the car backwards... then sometimes the key will turn...
    i can also take the key out while the car is on??is this normal, was told it was bcos of there being no boot release? i find that hard to belive.?
    do i just need a new key? the one i have is quite worn...
    is this a common problem or am i just a complete idiot????
    thx for ur time
    Mar 2004
    Melbourne
    Poo-goat 307
    Quote Originally Posted by <sloth> View Post
    how would you turn the car off if you locked the keys in the boot?
    Jun 2006
    Sydney CBD
    FD2 4DR 2009
    i think he means not engine on but the power stuff like the radio and stuff.
    Newcomer Array
    May 2005
    melbourne
    94 crx
    no, i can take the key out when the engine is on.
    i ll have to remember not to lock my keys in the car... or the boot as i only have one key.........
    any help?
    Newcomer Array
    Oct 2006
    North Brisbane
    ED Crx
    sounds like its your key, take your car to a locksmith and like im not sure how they do it but like they look up the code or something for the key and cut a new one, like not just a copy cause other wise u will have the same problem
    i had a similar thing on my old accord, the key was really worn only difference was it wouldnt work in any of the locks except the drivers door and ignition, and i could take it out of the ignition when it was going too, just got a new key and it was all good
    Newcomer Array
    May 2005
    melbourne
    94 crx
    thank man,
    just what i needed to hear. do u no how much$
    does any1 no where i can get a honda key?
    Newcomer Array
    Oct 2006
    North Brisbane
    ED Crx
    um pretty sure its only like 15-20 bucks for a new key, like thats just for a normal key, dunno where u could get a blank honda key from maybe from honda, but it could cost a bit, and not really any different from the key u'll get from a locksmith except it will say honda lol
  8. #8
    might be the ignition barrel thats f***ed
    try putting any other key in to see if it starts
  9. #9
    TRIPLE OG Array
    Aug 2004
    MEL/JPN
    b18c crx/that's
    get a new key cut then go from there. it's the first step, if you still have a problem then look at other options. in most cases the key will do the trick
    www.lozzz.com - car spotting, food and other random crap from Japan
  10. #10
    Newcomer Array
    May 2005
    melbourne
    94 crx
    cheers guys,
    will try any other key, then get one cut.
    thanks for the help
    will let u no what happens.
    thx
    paul
