I have an 11/85 Prelude manual A20A4 12 valve, fuel injected with 4WALB.
I recently had the brake pads changed and now the brakes wont work correctly.
When you depress the brake pedal the fluid from the master cyclinder pumps back up through the two solenoids and into the ABS modulator unit resevoir causing overflow of fluid. Continued pumping of the pedal drains all the fluid from the master cyclinder and makes quite a mess.
I have removed the two solenoids and replaced/checked their operation and o-rings with information from the Honda UK manual web site. When I power up the red wire to the solenoids it dosnt help but when I power up the yellow it stops the problem but you cant depress the brake pedal.
Any ideas?
Cheers,
Grant4561
